Done :)
:domokun: Oops forgot you where female; buddy just doesn't sound right, when referring to a female, sorry.
LOL no problem... just bring your car up for one of the NSW SAU events being held in Canberra next year and we'll organise some pics
hmms.. how do you win stuf :dry:
This is the email they sent me...
To celebrate the month of December and the end of 2007 we are very pleased to be giving away one of our most popular products - the Greddy Profec B-Spec II boost controller.
To win the Greddy boost controller you need to have the highest vehicle rating of our Members at the end of December. To reach the top 10 vehicles, you currently need around 20 votes of 4 stars or higher. Spread the word of our range of high performance parts and new members section to increase your chance of winning.
Congratulations goes to our November winner of the Greddy Full Auto Timer, Gary with his Toyota AE111 Sprinter. Gary's Sprinter features parts from HKS , Fujitsubo, TRD, Apexi, Power Enterprise Cusco and many others.
We are sure the Greddy Auto Timer will ensure Gary's impressive Toyota will have a chance to cool down after a hard run on the street or the track!
So I thought it was worth a try at least LOL
  • 3 weeks later...
Email from Nengun
Sent: Thursday, 3 January 2008 1:17 AM
To: Michele
Subject: nengun performance
Hello Michele
This is Brent from nengun performance. I would just like to say you came very close to winning the Trust B Spec II. If you added more about your car you probably would have won. Oh well, better luck next time. Scroll to the bottom of this e mail to see who the winner was.
Only Joking. Actually your vehicle was voted most popular, so you won the Trust Boost con . So if you give me your details I will send it to you asap. With your permission we would like to show case your vehicle on our front page. It would be nice if you could add some more details on the vehicle.
Best regards
Brent
Japan
www.nengun.com
THANKS HEAPS EVERYONE!!!
Now I need help with putting more info in about my car... I don't know what people want to know about the car, can anyone help?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
