4x 18" mags. Came off an R33 Skyline. Tread needs replacing.
Condition is average/good with some gutter scratches.
The set $500
4x 16" mags. Came off an R32 Skyline. Tread needs replacing.
The set $250 SOLD
or both sets for $600
Edited by 11DOU
https://www.sau.com.au/forums/topic/197876-16-18-mags-full-sets-with-tread/
  • 3 weeks later...
I am in brissie and very interested, and I will take the rims tomorrow if they are the correct specs....
if you aren't sure, it should be written on the inside of the wheel.
Also, where in Brisbane are you?
I hope to hear from you soon. Thanks,
Beau
Edited by insanity
Sorry If I have not replied to anyone. I haven't had much time to get on the pc.
They are 265/55/R18 5 stud and I think the specs are 118x8.5 but not 100% sure. They came off my old R33.
My number is 0433 581 362 and I'm located on Brisbane southside, windaroo, beenleigh exit off freeway.
Hey mate. Just noticed you've probably made an error with the tyre size. They're most likely 265/35/R18
Cheers,
Jarrad
Edited by jabtronic
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
