Hey guys as above, looking for Xenon's (Preffered) let me know what you have, and how much... not interested in making offers and playing bidding war games.
if you have either, let me know asap and i will take them at the right price.
cheers
https://www.sau.com.au/forums/topic/198797-wtb-r34-xenon-headlights-pair/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
