Ben, what temperature does your dot 5 boil at? There's an expensive dot 4 from Caltex that boils at over 300 degrees. I forget the exact name (it's in my garage atm but it's too cold to go out and look), but it's around half the price of yours. Race Brakes use and recommend it :rolleyes:
https://www.sau.com.au/forums/topic/19907-pineapples/#findComment-420635
dan_the_man
Yup thats exactly how they work, good stuff eh !
JimX
I believe its 320-330c. I didn't really have time to pick and choose, thats what my brakes specialist had and i didnt have a brake pedal to get me around town to 'browse' so i used it. I was actually expecting like $120ish for good quality stuff so it worked out ok in the end.
https://www.sau.com.au/forums/topic/19907-pineapples/#findComment-420717
N/A®, I never heard any knocks on mine, instead the back end used to shift left to right over every bump (did the crab walk). Either your subframe bushes are really worn or you've got other suspension issues to work out or it may be as simple as an exhaust mount thats worked loose. Have it checked it out.
https://www.sau.com.au/forums/topic/19907-pineapples/#findComment-430463
  • 3 weeks later...
bought the whiteline kit with 4 pineapples but used only 2 in the standard position, what do you do with it? Is it better to use it in the all-round position as the postions described are drift,drag,standard and all-round.
btw with the new nolathan bushes in the front castor rod and the pineapples, car feel more solid, more direct but more bumpy.
https://www.sau.com.au/forums/topic/19907-pineapples/#findComment-471449
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
