ITEM NOW SOLD
For Sale - 3 x 60mm Aluminium Gauge Holder for the S13 Silvia or 180SX Centre Air-Con Vent (2nd hand, but as new)
Located In Brisbane - Pickup for $30
Or Will Post Australia Wide for $40 total.
No modifications to this part are necessary. This will fit all S13's and 180SX's This will possibly fit other Nissan's if you can confirm the centre air con dimensions with that car. (68mm high and 211mm wide). Simply remove the centre air con vents, and then selastic the back of this part in place. I had 60mm Defi BF Gauges in this for 2 years without a problem, and they fit 100% perfectly. When they were fitted the edges of the gauges did not hit as you can see in the pics.
Check my signature, and contact those people for my positive trader history.
I accept paypal payment for the mexicans outside of Brisbane - PM me with your email address and delivery address and I will send you a automatic payment request.
This part will not be put on hold! Don't post if you are not interested - Cheers.
Edited by silman
https://www.sau.com.au/forums/topic/199177-sold/
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
