Item: 6 X 480cc injectors from JDM manual s15
Age: from 2001 s15
Condition: great, flow tested and cleaned
Price: $400
To Fit: (What car) any with rb25det non neo.
Contact: 0401723975
Comments: was going to drop them into my engine but plans have changed, regretful sale.
2 injectors will need some O-rings
the other 4 are still sittting in the s15 fuel rail.
Edited by eddieeeee-ro
https://www.sau.com.au/forums/topic/199645-sold/
well most will say 480cc is good for 250kw with 80% duty.
so i guess if ur running stocks this can only be better?
btw i wouldnt run the stock injectors @ 100%
https://www.sau.com.au/forums/topic/199645-sold/#findComment-3558969
Yeah thats true. Imagine getting just a bit of build up in the injectors due to a dirty fuel filter or bad fuel = ping ping ping.....
https://www.sau.com.au/forums/topic/199645-sold/#findComment-3563060
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
