hi all i have a r33 with the standed r33 thermostate in it , what im after is one that opens around 62 degand not a 150 buck nismo one surley there must be something that fits . any help would be great ive done the search thing without much luck .
cheers dean
https://www.sau.com.au/forums/topic/199847-themostate-temps/
nismo themostate is the best!!! and good price
150 bucks is far to dear for a 62 deg thermostate just cause its got a nismo sticker on im not paying for wank value .
im sure there are other 62 deg thermo made by other companys that will work exactley the same . i dont see nismo thermostates stuck in every nissan ever made. i will go thru the catalogs from our suppliers when im at the workshop next
Why do you want a 62 degree thermostat? That's too low a temperature for maximum power or minimum engine wear or maximum fuel economy.
Cheers
Gary
cheers for that gary
i thought if i got one that opened a bit earlier it might help with my cars prob of running to hot in hilly areas on 40 deg plus days . how ever i just pulled my old one out and stuck it in a saucepan on the stove it did fully open but the water was almost boiling b4 it started to move at all .
so i suspect the one thats in there is not playing the game right atm it is a standed nissan one 76.5 so i think i will replace it with the same type as the one i just pulled out
thanks for your advice
cheers dean
Cheers
Gary
gary, what is the best temp? I am getting a constant 91 deg, doesn't matter how cold it is outside... and on hot days it goes up to ~95-98... I am used to my other car running at ~80deg, what is optimum for the stag?
-Ryan
-Ryan
Ours usually runs mid 80's normal driving and high 80's when pushed. Time for a radiator flush perhaps? Or maybe a debug, ours was a bit clogged with dead insects last summer.
Cheers
Gary
Cheers
Gary
sounds like it... was planned for next service, but might have to do it sooner... i sent thru a PM for matt BTW
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
