Hey Guys got 2 Electric Standard GTR Mirrors Silver in colour In good Condition Asking $150 ONO For The pair , or make An offer ( Reason For selling i have upgraded to m3 Style Mirrors )
I also Have 2 Pieces Of the front Part of a Roll Cage Asking $200 ONO ( Very Cheap considering a full roll Cage Goes for $1000 Plus , Reason For Sale is because I bought the Car With the full roll cage but as i turned it into a street Car i Only Use The back half of the Cage, This is ideal For someone who is wanting to make a Cage , You will have the front 2 Pieces all you have to worry about is the back ones after ...
Still have a Set of 6 GTR Standard Pistons , One has Crack in it $100 ONO ...
Any Questions Please Ask ...
https://www.sau.com.au/forums/topic/200050-r32-gtr-parts/
  • 2 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
