Make: Nissan
Model: Silvia Q's
Engine: Blacktop SR20DET
Milage: 163,000 on dash, 98,000 in front cut
Transmission: 5 speed manual
Colour: bayside blue
Complied? yes
RWC supplied? yes
Currently registered? yes, expires october 2008
Price: $15,500
Contact: 0407 931 097
Comments / Modifications:
Alot of time and money has gone into this car to make it a tough street car that is capable of circuit racing, but I'm in a bit of a situation where I think I'm going to have to sell it. Below is a list of the details:
Suspension/handling
- 16inch lightweight Intermilano wheels (sounds like they're italian but actually made in Japan)
- 5 stud conversion using s14 front/rear hubs
- R33 Skyline Front calipers and rotors, brake master cylinder and rotors
- Front and rear cusco strut braces
- Tein superstreet coilovers
- Nonathane front castor rods bushes
Engine:
- Blacktop sr20det from 1995 180sx
- Serviced head with new valve exhaust valve guides
- Tomei metal head gasket
- Tomei Rocker Arm stoppers
- HKS Step 1 cams, 256 intake and 264 exhaust
- GT28R turbo with upgraded wastegate actuator
- Z32 AFM with stainless steel intake pipe
- R32 GTR Front mount intercooler
- 3 inch straight thru exhaust with stainless steel hi-flow cat
- GFB plumback BOV
- Apexi Power FC with Hand controller
- Turbosmart boost controller
- Nismo 550cc injectors
- Walbro 500hp fuel pump
- B & M oil cooler
Interior:
- R32 GTR seats
- Pioneer MP3 player
- Greddy Boost, oil temp and oil pressure gauges
Body:
- Resprayed in Bayside Blue 5 months ago
- GTR style Front grille
- tinted windows
Car was tuned by CRD and made 204rwkw @ 16psi. Expecting it to make between 210-215 at 18psi. Will be going back in two weeks to CRD to retune it with the new wastegate actuator and more boost as my old actuator was not holding boost above 15-16psi. For those interested in the car, you're more than welcome to come see the car on the dyno if you like.
I have all receipts for all the work done and will provide these to the buyer.
Edited by Demon
https://www.sau.com.au/forums/topic/200771-1990-nissan-silvia-blacktop-sr20det/
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 5 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
