hey guys i recently bought my skyline and it used to be a mb quart filled demo car from gt autosound in adelaide. anyway when i bought it he couldnt sell me the speakers cos they werent his, so to be a nice bloke he bought some sony xplod subs and 2 amps for me 2 install when the car got 2 me,(and yes i do realise sony xplod are crap) but i dont care i dont want them i just wanna fill in the holes no point havin fully sic boot that has no doof lol anyway, i dont know that much about amps and the 2 he has given me are xm 754hx which is your normal run of the mill amp, and xm-504x which is a stereo power amp (see pic below) ,and i have know idea what the xm-504x is for is it for my parcel speakers?? or is it for one of the subs i got no clue please help
ps sorry for the bad grammer and if its a noob question cheers
https://www.sau.com.au/forums/topic/200826-sony-xplod/
It breaks down like this -
You have a 4ch and a 2ch.
On the 4 channel, you need to bridge 2 channels (the rear two) so that you can run a pair of speakers as well as ONE sub of it. (should be indicators on the speaker terminals on how to bridge it) and run one of the two subs off it as well as a pair of speakers (pref fronts).
THen bridge the 2ch (502Z) into one channel, to run the other sub.
The reason you cant run both subs off the one amp is that to run the subs you need to set the frequency cutoff to LPF (low pass frequency). You can only do this with the rear channels on a sony amp.
https://www.sau.com.au/forums/topic/200826-sony-xplod/#findComment-3572498
PS sony actually put out some VERY good products over the Late 06/Early 07 period - excellent for their money. Pity is that ur amps were in the series before that, so see how you go.
PS after a brief good run of a year there, sony are now shit again.
https://www.sau.com.au/forums/topic/200826-sony-xplod/#findComment-3572532
Ok so thats basically how you bridge the two channel to run sub B, run the two door speaker off the 4ch FRONT outputs, and run sub A off the 4ch's rear outputs, bridged together.
To bridge the channels, you use the negative of one channel and the positive of another channel. As said, there should be indicators on both the two and four channel amplifiers on which terminals to you.
Then, set the 2ch to low pass frequency (LPF), the rear channels on the 4ch to LPF, and the front two channel son the 4ch to High Pass Frequency (HPF).
In a normal world it would make sense to run both subs off the 4ch, sony only put LPF on the rear channels, and you cant run full frequency through a sub.
Any other dramas send me another PM
https://www.sau.com.au/forums/topic/200826-sony-xplod/#findComment-3574819
actually my friend, if you cared to view the picture of the amp, you will see that it allows LPF on both 1+2 and 3+4
inside the red circles are the filter settings, inside the yellow settings you can see where it says "LPF" on both sets of channels.
set both of these to LPF
then, set the lowpass filter dial to the 80mark on all of the filter dials.
set all of the low boost dials all the way to 0. you dont want these on, coz it will cause distortion
leave all the level dials where they are.
so you need to bridge a sub to each pair. so one sub to 1+2 and the other the 3+4
you will need to split the RCA cables though, from the single pair of subout, to 2 pair. one for each channel.
then use the 2 chan to run the front speakers
https://www.sau.com.au/forums/topic/200826-sony-xplod/#findComment-3574872
fair enough. Most sony amps dont run two LPFs but that definitely makes things easier for you, leigh!
PS lets not be a wanker, now, trism. Not everyone is perfect mate. Try not to sound like such a prick to someone on here who simply answered a PM for help. He asked for advice and a quick sketch and i gave him the info i had. Its great that you tracked down a pic of it and saw that, but you dont need to act like an ass to me about it champ.
https://www.sau.com.au/forums/topic/200826-sony-xplod/#findComment-3575052
sorry mate. dont take it to heart, i didnt mean to be offensive. its just the internet :rolleyes:
https://www.sau.com.au/forums/topic/200826-sony-xplod/#findComment-3576389
well id like to thank stage coach fopr his help but both of u have completely lost me i rekon i will just go 2 an auto electrician to get it done lol thanks for the help
dont take it to an auto electrician. their job is to fix problems to do with cars stock electronics. dash wiring loom probs, etc etc. not installing car audio.
take it to a proper car audio installer :rolleyes:
https://www.sau.com.au/forums/topic/200826-sony-xplod/#findComment-3576395
take it to a proper car audio installer :D
I second that motion, trism. Im forever fixing things caused by auto elecs. (wrong guage wire (eg 16GA earth to a 1200W mono, with a 4ga pos).
Standard price to have a 4ch and a 2ch installed (wired and mounted) shouldnt exceed $250 all up.
Try autobarn, supercheap, strathfield.
https://www.sau.com.au/forums/topic/200826-sony-xplod/#findComment-3576744
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
