Hey All,
Well after some deliberation, I have decided its time to move on to a new car :thumbsup: So in order to do that the Skyline is for sale!
SOLD
Spec's are:
1996 Series 2 Sedan
Sideskirts
Apexi WS coilovers
3 inch cat back 5 Zigen Exhaust
Limo Tint on rear Window
Aftermarket Clutch (of unknown origin)
Shortshift kit (of unknown origin)
New Pioneer MP3 head unit
Blue Indicators and Headlight globes
3 Point Imobiliser + Remote central locking
Price: SOLD
Rego: May 08
Pic's:
As most of you know I am the first owner of this car and currently has rego till May 08!
I am looking for a change as per usual and am interested in the following:
S14a
R34 Gt-t
or anything that may be of interest
I can be contacted via pm.
Cheers
Phill
Edited by phillb
https://www.sau.com.au/forums/topic/202421-black-r33-series-2-sedan-sold/
  • 3 weeks later...
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
