I have ONE big day out ticket (Sydney) for sale! Unfortunately i cannot make it :blink:
Located in Newcastle/Forster, i can express post if need be.
$190
PM me if interested!
Edited by BazaR33
https://www.sau.com.au/forums/topic/202470-bdo-ticket-sydney/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
