i no you said syd but theres a place in newcastle that i gt mine from called east coast autos that i gt my r33gtst from and i spoke 2 him last week and he got a few non turbos just in from jap for peple just like u.
if ur intrested pm me and i find out wat hes gt in stock
I dealt with Cosmopolitan Cars on Parramatta rd and they were excellent to me. Fantastic car in great nick. Haven't had any issues with the car at all, apart from things I've done...
Plan on going back to them to get my next import...
+1 for Northshore Prestige
I was recommended to Nth Shore Prestige last year. Visited their small but tidy premises and workshop and was impressed at their condition of cars. Add another benefit of Ben who was very easy to deal with and no sales pressure at all. Went back there a few days later and purchased an R34 sedan. 4 months down the track I decided i need a bigger car so went back to Ben and he gave me a deal for an NM35 Stagea. I traded the R34 in for next to the price that i purchased it for, plus he gave me a $4k discount on the Stag. There's no way any other dealership would give me such a deal.
3 months after owning the Stag, the right front wheel bearing started to expire so I took it back and they covered it under warranty, even though it was just out of the 3mth warranty period.
I was so impressed with how they conducted their business that I have told many ppl about them. So much so that 2 parties have already purchased their imports through Ben.
On top of that, I bought my third car through Ben last week. He charges no fees for finding the right car for you in the Japanese auctions, as long as you comply the car through their workshop. He gave me a detailed summary of the breakdown of the costs from fob price, shipping, duty and gst, compliance, and other misc costs. This information proved very handy as I could compare it against other big online importers such as Prestige Motorsport, Imports 101 and J Spec. It worked out cheaper than all of the 3 mentioned importers, and in one instance, it was several thousand dollars cheaper.
Their website is www.northshoreprestige.com.au
