Selling my beloved 200. Bought the car just over 3 years ago with 265,xxx on the clock and have since had it rebuilt and put lots of time/money/love out into it. It has been my daily as well so I've always made sure driveability and reliability are up to scratch (serviced every 5000ks etc). Reason for selling: Buying a bike and getting out of cars for a while
Engine:
Blacktop SR20DET (compression even across all cyls)
HKS 2540R turbo (rebuilt with GT2876 core)
Nismo forged pistons
Nissan metal head gasket
Nismo 555cc Injectors
Bosch 550hp Fuel Pump
Bosch 80mm AFM (z32)
Custom alloy intake pipe
Apexi Power Intake
Cooling-Pro Oil cooler + remote filter
SARD R2D2 BOV
3" turbo back mild steel exhaust w/ stainless cannon
Rocker arm stoppers
FMIC
GReddy sump
Engine damper
Suspension:
HKS HypermaxII coilovers w/ camber tops
Front strut brace
Rear camber arms
Interior/electricals:
Kenwood KDC-MP4029 mp3 head-unit
Pioneer TS-C1625 component front speakers
Kicker K60 coaxial rear speakers
Momo shift knob
Apexi AVC-R
Apexi PowerFC + controller
3x Smoked face Autoguage gauges (Oil temp, oil press, boost)
Mongoose Alarm
Exterior:
17" Genuine Volk TE-37s
Other info:
Has sunroof + airbags
Have receipts from engine work done and logbooks tracing back to original owner
Engine has roughly 20,xxxks on it since the rebuild and the chassis has 302,xxxks on it.
Car has a couple of problems atm. The gearbox whines a bit but other than that is in good condition (doesnt crunch or anything) and there is a misfiring problem which new coilpacks will fix (works fine with the spark gaps tightened up but pops a little on idle). Couple of dents on the bonnet from something being dropped on it (damn shopping centres :pissed: )
Tuned by Matthew Spry (PITS) and made 190rwkw @ 18psi with a fairly conservative tune. His dyno is known to read quite low so just over 200rwkw would be probably where it's really at. A set of cams + more aggressive tuning will see this car making 230rwkw+.
Interior is in good condition with only the steering wheel a bit worn out. Exterior is good condition with only a few minor dints here and there. Front lip has a few scuffs and paint cracks from nudging parking blocks.
Located on the Gold Coast
No timewasters or tyre kickers.
Rego till Jan 09, can arrange RWC
Price: $15,500 (incl. dent touch up and coilpacks which I'm in the process of doing)
Jamie - 0403137337
Edited by Jum
  • 3 weeks later...
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
