I had this posted in the QLD / Events section but after spending more time here in the motorsport section I think it might be a more appropriate place to post it. Round 1 is only just over a week away on Tuesday Feb 5.
I have also added Motorkhana to the event and it will be run all day in the carpark between the pit bays and the sheds. For those who remember my big electronic sign and timing beams I have converted that system to do Motorkana so the crowd can see the elapsed time live.
Time Attack Series 2008
Event:
There will be a 6 round series, requiring each driver to complete 3 Sprint Track Rounds and 3 Clubman Track Rounds.
There will be 4 half track days for each of the clubman and sprint tracks that will be eligible for points.
The best 3 of the 4 of these half days completed by a driver will count as point’s rounds for that driver (A driver can miss a round on each track and still be competitive).
(The series is points based; therefore all drivers are welcome to any event as always)
The winners of each class, and the place holders, will be presented trophies at the end of the year.
Class Structure:
A: Street Class
B: Open Class
Division 1 (A, B): AWD - Battles of GT-R vers EVO vers WRX vers GT-4 etc
Division 2 (A, B): Forced Induction - Battles of 4/6/8 Cly 2WD Turbos, Rotaries, Skylines, BA's etc
Division 3 (A, B): V8 Naturally Aspirated - Classic Ford vers Holden with some Toyota power
Division 4 (A, B): Naturally Aspirated ( but not V-8 ) - All 4 and 6 cylinder cars including Rotaries
General Rules:
Nitrous prohibited.
Roll Cage Permitted in all classes.
The same driver must drive the same vehicle for the duration of the series. The combination of vehicle and driver shall collect points.
Modifications must not be made which reclassify the vehicle during the series. Points are not transferable between classes.
A: Street Class:
The Vehicle must be constructed by a major manufacture.
Must have a rear exiting exhaust system with a muffler.
Must be road registered.
Must have OEM glass.
Must have OEM doors.
Must have both front seats (can have a race seat and a standard seat) and basic interior in the front half of the cabin. (Removal of carpet, stereo etc and liner allowed but not the dash)
Must not have in cabin adjustable brake bias / pedal box.
Must have DOT approved street legal tyres. Tyres must not have “For race use only” or “Not for highway use” marked on them. The tyres cannot be grooved slicks etc (See tyre register thread for further details)
B: Open Class:
All cars that do not fit into the Street Class and comply with the general rules.
Points Allocation:
1st = 12 points
2nd = 10 points
3rd = 9 points
4th = 8 points
5th = 7 points
6th = 6 points
7th = 5 points
8th = 4 points
9th = 2 points
10th = 1 point
A minimum of 5 laps must be completed at a round to be eligible for points.
Tyre Register:
For the street class tyres must be grooved and some wet weather capability. Slicks are allowed in race class.
There is a tyre register so there is no confusion as to what category a tyre belongs.
Click this link -> http://www.timeattack.com.au/forum/viewtopic.php?t=139
If you have a tyre that is marginal please contact [email protected] for a ruling. Otherwise you may be reclassified on the day.
Rulings:
The organisers decision shall be final. No dispute shall be entered.
First Event: February 5
Want to Get Involved, fill out the Join Form at:
http://www.timeattack.com.au/mailing.php
And I will email you out all the details.
https://www.sau.com.au/forums/topic/203420-qld-time-attack-series-2008/
Yes all rounds are on weekdays, the calendar has been updated on the website for the year: 2008 Series Calendar
If you think you can make it to a round sometime during the year let me know in advance so I can secure you a spot.
Also, anyone who has run with us in the last few events, the Hall Of Fame and the Top Ten have now also been updated.
Paul
Ryan its Qld Raceway. Currenty the only track we run at until Lakeside becomes available.
Paul
Hey Paul, Top 10 2WD Sprint track, you've got the fastest time in 2nd position and Georges initials are GK not GC :)
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
