Make: 1994 series one
Model: gtst
Milage: 126000
Transmission: manual
Colour: red
Complied? yer
RWC supplied? no
Currently registered? yes
Price: 10000
Contact: pm or here
Comments / Modifications:3 inch exhaust with zetti cannon. cd player. 400r bodykit. good interior. lowered suspension. front facing standard plenum
Images:
Reduced: 66% of original size [ 909 x 682 ] - Click to view full image
the 400r front bar was broken from driveways so i replaced it with a standard bumper but its white and car is red. bonnet flew up so has small damage on the roof and has black painted bonnet on it. il get more pics later
  • 4 weeks later...
i know GTST was after a skyline under 10k, you could fit the profile..
expect i do have a few queries.
No roadworthy
No pictures
The link you sent amy was to a stupidly long post where people are asking for pictures, then eventually you send an engine bay pic from carsales.
I did a carsales search for 1993-1994 skylines with 100k+ on the clock and could not find yours.
is this is hope-that-people-buy-it-without-seeing-pics-and-no-roadworthy kinda bag?
I hear being above board is better then not telling people why it wont pass roadworthy etc. Im sure its not your fixed bonnet or the smashed front lip.
only saying this as i just sold mine and it was hard enough being straight with everyone. amazing how hard it is to sell the ol r33's. I had to sell mine way below market value and mine was in bloody good nic. 2 mechanics went over it and only said brake pads & a powersteering pipe would need replacing.
No roadworthy
No pictures
theres pics in the link on 2nd page i think it is. doesnt take too long to scroll down until you see the pics. the engine bay pic is from when i bought the car but i can assure you its still in there.
the brakes and steering and suspension and lights work. itl pass roadworthy depending on where you go. i dont have time to get one.
car for sale 8000
  • 4 weeks later...
i went to pick up the new bonnet for it the other day but it didnt fit in the 4b so il be back with a trailer in about 2 days. il get the bonnet painted gloss black and can have the bumper painted same colour as car.
buy it
  • 1 month later...
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
