Hi Guys
I have a set of 17" 350z wheels for sale with Bridgestone Potenzas RE40s with about 75% thread left
Specs of wheels are below:
Front
Offset: +30mm
Weight: 23.26lbs
Tire: 225/50/17
Rear
Offset: +33m
Weight: 24.14lbs
Tire: 235/50/17
Condition of wheel: Excellent
Condition of tyres: 75%
Price: $600 ONO
Will fit most nissans
Hi Guys
Front
Offset: +30mm
Weight: 23.26lbs
Tire: 225/50/17
Rear
Offset: +33m
Weight: 24.14lbs
Tire: 235/50/17
Price: $600 ONO
quite interested.. would you let me try them on my 32 to see how they fit / look?
hey just wondering do you know if these rims would fit on a r33 gtst. Also how much for postage to vic.
Hey mate,
I just fitted these to my R33, fit perfectly and look good too. Mine were 2 pairs of front rims (ie both all four 7.5 inch by +30 offsett), no issues front or rear. The rear looks to have heaps of room still, car is slightly lowered.
