Make: Skyline
Model: R33 GTST 93
Milage: 112k
Transmission: Manual
Colour: Maroon
Complied? You betcha
RWC supplied? wat dat (n/a in S.A.)
Currently registered? Yes til end of feb.
Price: 13,000
Contact:
*Wiseco Forged Pistons 20thou oversized
*GTR Rods
*ACL race bearings
*Trust 1.6mm Head Gasket
*Gates timing belt
*new water pump
*Splitfire coil packs
*FMIC Hybrid
*720cc Injectors
*Garret GT 3040 (installed same time as rebuild)
*Q45 afm
*4"intake with K&N POD
*GFB bov
*Full 3" zorst with 5" muffler (quiet)
*S/S high mount manifold
*38mm external wastegate
*Walbro fuel pump
*fuel pressure reg
*Extreme motorsport clutch
*chromoly lightened flywheel
*Dba slotted rotors on front
*Bendix Ultimate race pads
*Apexi Power FC
*Apexi AVCR
*Oil catch can
*17" rims
*400r kit with stealth spoiler
*Alpine TV,dvd head unit
*clarion splits in the front
*fusion 6x9s in rear
*2x jbl 1000w subs in boot
*jaycar amp (cant remember stats but its a class d amp)
*2way alarm
*Damper adjustable suspension
*hks springs
260RWKW on 15psi!!! Turbo capable of making 300+rwkw with higher boost (backed by forged internals)
Edited by Bugalugs.
https://www.sau.com.au/forums/topic/204129-sold/
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
