Hey guys,
Here is a photo of my keys:
The top button unlocks the doors and turns off the immoboliser, but the bottom does nothing. I was wondering, is it possible to make this button do something? I was thinking maybe turn neons on/off, turn engine on/off, headlights, maybe even open the boot or bonnet. Is this possible? Or does it have to live the rest of its life lonely
Thanks,
Rhys
https://www.sau.com.au/forums/topic/204314-spare-alarm-button/
How mechanical am I? Well I'm a mechanics apprentice, so I'd say yeh, sor sure. And now that I've just got my licence, I'm willing to drive any where! I really want this to work, mainly because it'd be cool to show off to my mates. How easy is this to do? A write-up or any information would be appreciated.
ok so you know enough to be dangerous :D
go to a wrecker grab an electric release from a late 90s magna - cable and all.
wire a relay off the CH2 output on the alarm (alarm is -ve trigger.) to fire the solenoid
disconnect the manual release and put the electric one in place
done.
wow, thought it would be more complicated than that! A few questions, where would my alarm be hidden? and does the relay come with everything from the Magna, or do I have to buy that seperate? I'll post up some pictures/videos/how tos when I get this done.
std 5 pin relay- get them anywhere. since you are in a wrecker grab one from a VK-VS commodore.
alarm is probably under the drivers dash. black box that has dynamco on it.
I had a look around at 3 wreckers today, would have been 5 but they were closed :-(, but couldn't find any. I might have to buy a whole Magna boot just to get it. I'm pretty annoyed that I couldn't find any today, but I'll have a look during the week.
its on the later ones. look in the glovebox for a boot button. from there rip the passenger rear panels out in the boot (where the antenna is.) and grab the actuator and cable attached to it. grab all the snaps as well.
  • 3 weeks later...
Talked to the guy at the Misubishi Wreckers and he told me the Commodore one would be better. It works with a cable, so I dont have to remove the manual boot release for this to work. I have the release solenoid, do I need anything else to install it? I'll be doing it next week end, so wish me luck!! Here is what I bought, from a VZ Commodore:
I'm mounted the solenoid and it will work fine. Now I have hit another snag. I can't find my immoboliser anywhere!! I have pulled my dash apart and looked everywhere around the drivers side and middle of the dash. The passengers side is just aircon stuff and the glove box. Where else can I look? I looked under the bonnet as well, but not surprisingly I didnt find anything. Any help on this would be really appreciated. Once I have found it, it should be a down hill run from there. This mod is a lot easier than I thought!
I cant arm/disarm the immoboliser without the doors locking/unlocking. I waited for it to time out, but still the only sound I could hear was the drivers side door. And it isnt in there, obviously, the trim has been taken off a number of times. Any other ideas? The mechanic at work suggested behind the kick panel, I'll try that tomorrow and see how I go.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
