Item: GReddy e-manage blue with both ecu harnesses
Age: bought this just before xmas
Condition: brand new never been fitted to anything!
Price:$400 but im looking for a quick sale so throw me your offers
To Fit: (What car) any car the ecu looms haven't been touched
Contact: sms 0415 174 310 or pm me
Comments: check out this greddy site for more info...
http://www.greddy.com/products/display/?Ca...;SubCategory=48
Edited by (n_n)
https://www.sau.com.au/forums/topic/204371-greddye-manage-blue/
hmm tempting but for $470 i could get it brand new from nengun.
assuming by "both" you mean ignition and injector harnesses?
Edited by made_guy
will be pulling my emanage out of my 32 soon as im upgading to stand alone ecu its 6 months old! would sell it for $250...have receipts of $1100 including tune
Edited by boosted_32
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
