Hey Moo did you end up finding out how much a trailer would cost for a day or two? i think i need one for next track day lol
nah not really, but you would be looking at an average of 100 a day. think it would have been a good idea considering the few problems people had down there.
  • 2 months later...
  • Replies 123
