I cracked...Finally an 11.8sec, 1.7 60footers on crappy nexen rubber on stock 16's.....350rwkw
It's to do with launching and gear changes. If I had micky t drag radials........???? yee ha time??
I used to get low 12's with 296rwkw, but I am not a professional drag racer.....
For example, that night the Riggolli boys were there with a 32 GTR, single turbo, stock eng 400HP at the rears, shitty tires with big wheels. Low 11s easy. They can drive and make the most of their equipment.
https://www.sau.com.au/forums/topic/205193-11-sec-14-mile/#findComment-3635386
im looking at 300-330awk so just wondering with enough practice what quater mile speed is possible
330kw should be an easy 11.2 - 11.5. I cracked an 10.90 with about 350awkw.
Have done about 20 passes all on standard box and no dramas yet, fingers crossed lol
https://www.sau.com.au/forums/topic/205193-11-sec-14-mile/#findComment-3638704
Definitely need 300awkw+ for an 11 sec 1/4.
Stock boxes are like a lucky dip when it comes to drag racing.... MMulti plate clutches don't help keep them alive, plus helps if you are nice on the 2nd to 3rd gear change.
https://www.sau.com.au/forums/topic/205193-11-sec-14-mile/#findComment-3638928
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
