Hi All,
I have a RB30/25 Motor for sale (Head to sump)
Series 2 Block
Port and Polished
VVT Removed
Hks Cam gears (Inlet and Exhaust)
Hks Cams (264's on either side)
GTR valve springs
Dayco Timimg Belt
Denso 770s injectors
HKS Fuel Rail
Splitfire Coil Packs
Forged bottom end
Hypertech Ceramic coated pistons with Hastings rings
bored 20thou
Stud Kit
Eagle H-Beam Rods
Hi Energy 8ltr sump
Balanced and Blue Printed
N1 Oil pump
N1 Water Pump
Honed, Decked
New Bearing and Gaskets
Much more but I can't think of it now.
Any questions leave them here or call me on 0401 670 923
Im asking for $5000ono
Comes with no Manifolds or Turbo as I will be putting them on my engine.
I'm Located in Clayton
https://www.sau.com.au/forums/topic/206059-fs-rb3025-motor/
is the engine set up for single or twin turbo????? also would u be interested in shipping to sydney??? my father works for toll..... if i can organise for toll to ship it up here would u be able to get it to the toll depot??? ill be able to provide the address for u to get to the depot once my father has cleared it with his work and gotten a final price and shit..... all u would need to do is get the engine to the shipping yard as they do not do pickups for these sort of things.... my dad said
Edited by punisher6942
https://www.sau.com.au/forums/topic/206059-fs-rb3025-motor/#findComment-3652846
The guy I bought it off told me it was built by RE. The motor has been stripped down and all the goodies are in it. I even have cam boxes etc for it. Im just going by what he told me. It might have even just been tuned by RE and bottom end built somewhere else.
Ill try find some other history on it but thats as far as I know about the motor
https://www.sau.com.au/forums/topic/206059-fs-rb3025-motor/#findComment-3658534
dude have u got any pics of the motor u can post up or email to me??? email me at [email protected] with all the details of the engine im VERY interested...... i may even be tempted to come down to melbourne to have a look at the motor also is the motor able to be started at all???? i wouldnt mind hearing it run if i do come down for a look......... get back to me asap plz
https://www.sau.com.au/forums/topic/206059-fs-rb3025-motor/#findComment-3661986
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
