Hi all,
On Sunday I managed to mount my HKS EVCIII in the "coin" pocket of my R34 GTT. The pocket I am refering to is the one on the right hand side on the lower section of the dash on the drivers side.
It did take a lot of cutting of plastic, but the pocket is still totally usable and closes and opens in the same fashion as before. My aim here was to add the EVC steathly to prevent prying eyes. Both my DINs are full so this is the only other place I could fit it without making big holes in the dash etc.
At the same time I mounted a dual cigar lighter under the dash (mounts just clear of the steering rack etc). This is for GPS, phone etc cables so I dont have cables running all over the car.
You can see it in the top left on the first picture.
All I used was a dremel tool, cable ties, some foam for spacing (it needs to mount on a slight angle in the pocket), and the general screw drivers etc to take the panel out (one screw on the left of the steering column, and 2 on the bonnet release). The rest is self explanitory when you take out the panel.
Let me know your thoughts people. :thumbsup:
https://www.sau.com.au/forums/topic/206520-ebc-in-r34-coin-pocket/
Not a Skyline but still in the family. S14 with Greddy Profec B in the ashtray. Very stealth. Controlling the boost in the RB20DET so part Skyline. And the pics make it look dirtier than it really is.
That looks great, very stealthy. And much healthier than smoking as well!!
Welcome to SAU btw. You should introduce yourself sometime.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
