Hey guys,
This is my last straw. Im selling my beloved GTR to try and force my way into Sydney’s home market.
25K firm
THE CAR: 95
Black R33 GTR VSPEC
70000ks
G4 Racing coilovers (fully adjustable)
4 new tyres
rego till November 2008
cat back exhaust
duel pods
original GTR floor mats
original GTR front and rear strut braces
turbo timer
17 x 9 inch 3 piece OZ RACING rims
brembo breaks
M3 style mirrors
400R front bar
immaculate inside and out
Has warranty till July 2008.
PIC’s
https://www.sau.com.au/forums/topic/207330-r33-gtr-v-spec-25k/
  • 4 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
