Since moving from Brisbane down to the Goldcoast I rarely take the old liner out onto th streets these days.
Thought I see who else lives down here and interested in possibly catchin up one night down here?
possibly do something similar to the tuesday night dinner thing the sau guys do or head out for a cruise or something?
so, any goldcoasters on here?
UPDATE
Meeting this Friday 14th of March @ in the undercover parking area in Pac Fair right next to the Mobil Quix Servo.
We'll be there from about 7.30pm onwards and will decide what to do there. It's mostly just a meet and greet for us skyliners but may end up going for a bit of a cruise or possibly go grab a feed somewhere.
Meeting this coming Friday the 28th of March again @ the undercover parking area at Pac. Fair right next to the Mobil Quix servo where we met on the 14th last time.
Meeting at 7.30 again and probably leave between 8/8.30 as we did last time.
We'll make our plans at the Pac Fair meeting point but it'll most likely be the same plans as last time except will be doing it backwards :thumbsup:
All are welcome, we had a blast last time with a total of 15 cars turning up to the pac fair first meeting destination.
ALSO....
Bring a UHF along just in case we do decide to head out for a bit of a drive.
then we've got communication between us all while driving!!!
Edited by QWK-GTR
https://www.sau.com.au/forums/topic/207367-goldcoasters/
  • Replies 163
Posted Images
right in the heart of surfers paradise
in one of the high rise apartments/hotel buildings.
Man, I can't wait to attend my first Indy,... looks like it'll be a party at your apartment ? lol. :(
Although I have no idea if Indy runs around there or not.
soopa; It would be cool to cruise with a GC110.
https://www.sau.com.au/forums/topic/207367-goldcoasters/#findComment-3670913
finally someone mite get something going down here! i usually drive all the ways up to brissie to go to tnd or other coffee meets and its a hell of a drive! im a tru coasty, used to live in broady and parkwood but im just on the border atm in tweed and still driving to brissy to meets! organise somethin on the coast and im there with bells on.D
https://www.sau.com.au/forums/topic/207367-goldcoasters/#findComment-3671241
we're getting there mate....
just a matter of seeing what interest we can gather down here :(
https://www.sau.com.au/forums/topic/207367-goldcoasters/#findComment-3671302
Good to hear there are some others kicking round the coast. Well count me in guys. Im up for almost anything as long as im not working or stuck at uni.
You can visit your boot now that your down here. Where about on the coast are you moving to?
https://www.sau.com.au/forums/topic/207367-goldcoasters/#findComment-3671813
I'd lvoe to come along, never been to anything like this (only owned the Skyline for a few days now) but would love to get to know more about the scene and the car itself!
Let me know
Welcome to the family. So which model are you now the proud owner of ?
https://www.sau.com.au/forums/topic/207367-goldcoasters/#findComment-3673986
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
