Its an auto shifter.
Pull up the fork and get it outta park, down to drive, push the fork in when in drive and it ratchets thru the gears 1, 2 and 3. Over drive is wired up to a little on/off switch near the snow / power switch.
Pull the old shifter off, position the new one, cut a hole in the tranny tunnel and run the cable thru. Some brackets courtesy of MV Autos adelaide where used. The cable setting and cutting the hole was the most difficult part.
It is certainly unique, and as u said, i dont think its for everyone lol.
Your install looks good with the manual surround. Iv got a BM pro ratchet in mine, i painted the case black as to not stand out so much but i like it.
Yeah thats cool how its black. Reason i wanted a mega shifter is cause the Pro Ratchet has been done before lol. But i havent seen one with the case painted black like that though lol. That very cool! :)
I got a bigger leather boot to sit around it to get rid of a lot of the chrome. Now it looks like the whole dash is coming out and will get painted in a colour a little less bright me thinks.
thinking of doing this sometime down the track
has anyone else done it or have any more pics?
are you guys running standard auto gear? or do you have manualized auto setups?
was thinking of going that route once ive finished engine mods etc, i hate how the auto kicks down off throttle would like to be able to hold a certain gear/more flexibilty possibly.
anyone have any comments on this?
3k stall and stage 2 shift kit is all mine has.
If ya wanna manualise it talk to Mike @ MV Automatics in SA.
If ya do manualise, dont get a megashifter. Pro Ratchet is easier to use. My megashifter is farking hard to punch around lol
  • 1 month later...
  • 4 weeks later...
Post your video here mate! :)
At Howie's request,
Here is the link to a video of my ratchet shifter getting used.
The switch to the right of the shifter is 4th gear, which is usually the o/d button on your stock T-bar.
Cheers to my brother for the camera work lol.
Let me know what you think.
http://www.youtube.com/watch?v=zAQGCmSEfDU
i got a 4spd pro ratchett 4 my r33 do i need the button 4 overdrive or can i make it the 4th gear
You could in theory rig up the switch for the (on/off) overdrive by having it engaged when selecting the 4th gear, however, the mucking around ya gonna go through to get it sorted out properly IMO outweighs what its advantage its gonna have for you.
Be a lot easier to hook up a missile switch or a straight ON/OFF switch in the centre console area.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
