Here is yet again more gear for sale:
Make a reasonable offer time all items listed in blue make a reasonable bid on
all items in red are firm prices!
Stock R33 fuel pressure regulator
Used
$20 $10
Genuine RB25DET water pump in box
good condition used
$50 $30
Bosch Wide band O2 sensor
used
$50 $40
Brand new Genuine Toyota Oil filter in box
suits 4A-GE/GZE, 3S-GTE, 2Y&3Y Engines
$10 $5
JAW Japan Shift light Brand new,With simple plug and play installation. Has been pulled
out of box to look at but has not been used
$100 (RRP $150) Sold
Starbo G-12 Turbo Timer
Used good condition.
$20
FET TB-508 Turbo timer
Used good condition
$20
Jaycar Digital Fuel Adjuster
Built from a jaycar kit. bult it myself works great.needs hand controller. dont need it now i have my power fc
$20
Small Nismo Sticker
$2
Brand new Genuine S13 Rear Silvia Bage
Still in box
$40 $20 (rrp $65-$80) Part # 99099-35F01
Brand New Genuine S13 Rear Nissan Badge
Stil in Packet
$20 $10 (rrp $30-$40) Part # 9909935F00
S13 SR20DET Steel intercoler pipe with adapter already fitted for blitz BOV
(from Stock cooler or arc upgraded intercooler to throttle body)
$40 $30
Autotecnica Horn button
Brand new
$5
All items now for individual sale
Buy all of this stuff plus all the gear from my other for sale post
http://www.skylinesaustralia.com/forums/Au...nd-t207193.html
and a stack of car audio gear including
Use all this stuff or sell it here or on other forum's or ebay it
to make a profit i dont care i just need all this suff gone.
Located in Sydney's Western Suburbs
All sales are cash only and you have to pick it up
$150 $100 $80 $50 FIRM for everything i want it gone including the audio gear
Kind regards
Dave
Edited by MR FLWLSS
  • Replies 49
Posted Images
Wide band O2 sensor, New oil filters, New subaru floor mats added
Toatal bargan price of $550 & $700 for the lot
Edited by MR FLWLSS
if you have anything you think i might be interested in im willing to swap the lot for something of interest to me :cool:
You sent me a PM, can you pm me a photo of the shift light out in the open.. I want to see the cover of it .. is it bling bling or black? what colour is the shift light itself?
price drop on total prices due to sale of hicas lock bar and digital speed meter.
Edited by MR FLWLSS
do u know if the flash light works of rpm according to the factory needle (which is a bit slow) or is it connected to the ecu rpm (realtime)?
actually its really cleaver its made so even a monkey can opperate it. it connects to power and thats it.
its rpm reference signal is the back emf that altinator produces. as the altinator rotates it creates pulses/bursts of energy, Because an altinator generates 3 phase ac current whitch is converted to dc current through a series of diodes. you might not see this signal on a multimeter however on a occyliscope it is quite clear. the shift light has a small processing box which captures this unique signal and uses it as the Rpm signal. kind of like a g-tech (i think thats what the gizzmo is called.) so the answer to your Question is yes it is accurate and yes it is real time but you will need to set it up. as there is no rpm specific setting due to it can be used in anything from a car to a truck. you have a knob to set the lights brightness (and let me say u need the brightness knob because the high intensity blue leds in the shift light are F%$king bright) and another with rpm low/high so an accurate working tacho is required to set it up. They are simple and easy so even the most car illiterate person will find it hard to stuff up the installation. Plug, play, set & Forget its that simple.
I hope that answers yours and anyone elses questions about the shift light.
Kind regards
Dave
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
