Hey guys I'm new to the forums, just recently got myself a 1990 32 gts-t type m which already has a full exaust, cooler, filter, bov.
Previous owner had the car dyno'd without all them mods and got 159 at the wheels, and said that he estimates it at around 170-180 now.
Since having the car for around 2 months now I feel like I want more power, but I'm still very new to the whole car scene and wouldn't know where to start.
So I just wanted to ask all you skyline guru's what would be the most effective, resonably priced and reliable mods to get to reach my goal of 200 at the wheels?
Also what kind of money am I looking at spending?
Thanks in advance.
Edited by ray32
well i guess it depends on how much you willing to spend.
id say its 159rwkw with the pod and zorst,dont worry about the bov thats just toss-factor.
id say suspension first.always makes a huge difference in the car.
Edited by FATAZZ
Yeah thats the thing, I wouldn't know whats a good budget to work with.
With suspension I was looking at a set of Tien HA's, there are always a set or two floating around eBay resonably priced, will they do the job?
POD, Electronic boost controller (best option), SAFC, FMIC to make it safe, Full exhaust from turbo, fuel pump, regapping plugs to 0.8mm
200 rwkw there u go
Suspension was second thing I did .. I like tight cornering and wanted control.. a sway bar is also a ++++ makes massive difference
Edited by DECIM8
i got king springs and Koni shocks,nothing too fancy.Also while your there,change all the bushes.
i've gone the rb25turbo($400) like alot of people on here,i think std the best you'll get is about 180rwkw before you highflow($800-$2000) it then will net your 200rwkw mark.
Or get a new turbo from garret or hks or whatever.$$$$
Theres a group buy on here for all suspension components aswell,check it out.
Depending on budjet, i;d be saying get a boost controller whether it a manual stage 1 bleed valve of an EBC (electronic boost controller) this will up the boost, as you already have pod, exaust, FMIC? this should be getting closer!!
RB25DET conversion??
the sort of money you are looking to spend for all the other mods might be comparative to this option. 25% more donk! of course this isnt easy, but neither is fitting fmics... my R33 just cost $1300 for the privilege.
just got it back. should be good for 240rwkw with a final tune!
happy modifying.
True sorry missed the Rb20 comment..
Add the following
Oil cooler, Power FC, and Highflow Turbo running 20psi lol
Oh .. and fuel reg
Haha gettin' closer now! :P But yeah all the above mods will get you the power you're after for now, until you get bored and slap on a dirty garrett and some injectors :D
There probably is a thousand threads, but like most people you can't find exactly what your after so I made a new thread.
Well good sir, now you see why there are 1000 threads like this :P
Because...
1. You dont know what you want.
2. You dont have a budget.
3. Have not provided use/aims for the money spent
These types of threads always go down the same line, without filling in the 3 blank points above... people can offer solutions till the cows come home, however if you want suggestions that are actually useful, then you must be far more specific.
Oh, and for the record, you wont have 170-180rwkw on a stock turbo'd RB20, its reading a GOOD 20-30rwkw higher than it really should as the RB20 turbo is a tiny tot.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
