Item:Sard Pink Top 650cc Injectors, done 500Kms since being cleaned and tested
Age:Less than 12 months old
Condition:good condition
Price:$550 + postage
To Fit: (What car)R32/33GTR
Contact:[/b
Comments:PM Me if interested., Thanks.
https://www.sau.com.au/forums/topic/207860-rb26dett-650cc-injectors/
