not that i know of on the net but that would be very handy!
but ive been told go to motor traders and tell them the make and model of the car and they can get one possibly in stock, for a couple of bucks. not sure if the couple of bucks part is true, but im sure you can get them from there.
https://www.sau.com.au/forums/topic/207886-tyer-placards/#findComment-3676884
yeah i got my last one from joe at wheelworx then the one after that from sinergy but they where both just printed out bits of sticky papper and just dont last. was only like $5 but its finding the time to go there and get it haha
https://www.sau.com.au/forums/topic/207886-tyer-placards/#findComment-3679415
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
