Hi
i bought my car few weeks ago and cant figure out why i cant turn off/on tcs, the light in dash board doesnt come up after i press the tcs button, wheels dont spin at all. i check fuses but all seams okay.
Anybody have any idea what couse that problem ?? how can i solve it
btw is it normal in rb25det that engine afer 40 mins driving is hot for next 4-6 hours ??
thanks in advance
https://www.sau.com.au/forums/topic/208974-tcs/
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
    • did someone fill up the tank with rain water? lol
    • Slapped a HDi front mount on the M35 last week.
