ill give you $20 for the lot.... you know im good for it danny
how many blow jobs do i get with that :D
Do you have dash cluster (speedo, tacho etc..)
i do but im not sure if i will need it for my conversion ill let u know if i dont!
PM sent :D
pm replied buddy!!
  • Replies 65
Posted Images
yeah he needs to start building another toy so he can watch it get dusty and never drive it!!! So reckon ur best bet gingy is to sell me the running gear and brakes. :(
Hi mate would you take $70 for the R/H rear light and $15 for the plastic underneath the the steeringwheel column where the fuse cover sits in.
its a bit cheap for the tail light bud, and would be a pain to send the bit sorry
as said prefer S.A buyers
cheers
Edited by shy_s6
cheers
No worries bloke, that's understandable to try and get wreckers prices if your in the game, cheers all the same.
come on post the tail lights u know u wanna:P i need the left hand side one... just think... one trip to the post office and you could get rid of them both:) send me a pm if you change ur mind about it.....
hey mate im after a handbrake, whats the handle condition like, could you send me a pic, I have a series 1 but im guessing they are the same, also do you have the plastic air vent that sits up top on the right underneath where people normally boost gauges, and one last thing im after is a round rubber stopper that sets the bonnet height at the front they just scew in. I offer $50 delivered to Brisbane.
Edited by SevenAngryPenguins
hey mate would you be able to send pix of the front right guard to [email protected]
also interested in side mirror drivers side if u have it still.
ok guys hit me up with PM's would you have any idea on postage per taillight? ill do them for 80 each plus postage :thumbsup: im sure you could find the plastic under dash bit local
Hey dude. Im after the standard airbox and standard CAI. Do u have em???
sorry bud came with a pod filter
you can come look if you want bud, gaurd is straight apart from front tip slight paint crack n a paint scratch should be able to fix with touch up and also there would be a little bit of glue stuff on the bottom rear of gaurd as thats where the sideskirts join, mirror is perfect
do you have head lights and Grill?
all mooshed sorry
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
