Rb25, Rb30, R33 Parts Adelaide, Sa. Block, Stock And Aftermarket Parts - Intercooler, Airbox All Sorts! Cheap!
Clearing out the garage a bit, previous plans are falling through due to money so selling off parts I no longer need...
Complete good condition S2 RB30e bottom end ~$100 **SOLD**
Complete good condition S2 RB25det bottom end ~$350 **SOLD** (134,XXXkm - still hone marks)
2 R33 Complete Air Boxes ~$50 each **ONE SOLD**
2 R33 (rb25det) Standard Dump/Front Pipes ~$40 each
2 R33 Standard Intercoolers (all pipes and brackets) ~$60 each **ONE SOLD**
T04 External Gate turbo with T3 flange $350 (Paid $900!) It is used, but great condition, minimal shaft play
(little to be expected as bearings are wet float design)
RB25de Exhaust manifold ~$50
S1 RB25 AFM (perfect condition) ~$100
S2 RB25 6 Coil Packs (perfect condition) ~$150
S1 RB25 6 Coil Packs (perfect condition) ~$150
S1 RB25de (can be used on DET - minus boost solenoid) Complete Wiring Loom ~$180
S1 RB25de ECU ~$150
Prices Negotiable. Ph. 0433333647 or send a PM.
Cheers, Jack
Any1 with a VG30, rb25 or r34 T3 turbo I'm interested for swaps and/or cash. Lookin around the $3-400 mark for a turbz.
Cheers, Jack
Well I have 3, 2 DET and 1 DE. The DET can be used for both, and the DE can only be used for the N/A because of where intercooler piping goes.
I was told it's rated to 500hp. I don't know anything else about it sorry. I don't even know what brand it is.
Jack
i need a s2 rb30 block.
ill msg in a few days and see if u still have it (got WAY too many uni assignments due this week so im flat out and no time to work on cars). This would be easier and quicker then upullit :ninja:
  • 1 month later...
    • Jax Tyres this Monday morning. Front lifted 15mm Back lifted 12mm Quote1, $175 per tyre + wheel alignment. Quote2, $660 inc wheel alignment. paid $298 for the lot.
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
