Tring to diagnose my rev dropping off issue, i was just wondering what in the car changes when you reach operating temp?
My car is 100% fine until it reaches operating temp at which point it will randomly drop revs when i slow down/brake, and the idle will go up and down from 50 to about 1000 instead of being steady.
For what its worth, ive already cleaned the aac valve, but when i unplug it while the cars running it makes no change to the engine sound.
Also gave the afm a spray with contact cleaner.
Also using the stock bov.
So, what changes when an s2 r33 gtst reaches its operating temp?
Edited by delljit
https://www.sau.com.au/forums/topic/209741-just-starting-vs-operating-temp/
It sounds like a vacuum leak...The first thing I would check is your AAC valve which you have already done....
Also check your CAS is tight and hasn't rotated...Not likely but easy to check...
Also check all of your intake pipe work as well...When you drive it does it still make boost normally???
All EFI cars have a cold starting maps and as the car warms up the tuning will change...The ECU targets an idle set point but only adjust AAC valve to do this...So a vacuum leak may not make as much difference when the engine is cold so it appears to be normal but chnages when it warms up...
yeah it boosts fine
only thing is once its warm and the idle goes whack, the vac (factory boost gauge) goes whack too
The manifold vacuum will always drop as rpm drops...this is normal
Have you done any recent mods??...Also disconnect all sensor plugs and spray with contact cleaner or CRC to make sure they are ok...Do all of the ones you can see..It wont be wasted even if you do ones that are not likely to make a difference...ie fuel injectors...
Also turn on AC and see if that make any difference...if it does it is most likely a vac leak or AAC problem...(turning on AC open another solenoid next to the AAC solenoid)
how do i get into diagnostic mode to get a fault code? all i see thru searching is hizas diagnostic mode
sorry if thatsa dumb question but i mightve missed something witht he search function
edit: nevermind i think i found something http://www.nissansilvia.com/forums/index.p...amp;pid=3180541
ill try tomorrow since i have to goto work now
Edited by delljit
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
