Hi all..
So i was wondering if anyone has got a remap done from toshi? Road tuned or dyno tuned!!
Would love to hear your thoughts.
For about 500 bucks i think its a good deal.
more info in his thread here: http://www.skylinesaustralia.com/forums/Re...no-t210097.html
Should i do it or not is the question lol
Also if anyone in sydney has got it done, can i come check our your car lol...
Edited by siddr20
https://www.sau.com.au/forums/topic/210316-anyone-got-a-toshi-remap/
  • Replies 49
Yea i tried calling him today actually.. He was in a meeting.. Will try again today!!
Edit: yea just spoke to him then.. He was very happy with!! Fuel ratios were spot on..
Hmm might give this a go..
Edited by siddr20
I think the remap has a lot more potential than the safc, by the looks of things pointed out by toshi.
Safc, will just basically tune your air fuel ratio's and thats it. Well you adjust the fuel curve, but i think the remap can squeeze a lot more power.
Safc will probably also cost a bit more than the remap.
Hopefully someone else can explain the difference better than me..
Well im gonna give this remap a go next week probably.
Obviously you stated your getting Toshi to do this remap, just let us know where you had to take your car,if he did it on a dyno or street,how much, and roughly how long and seat of pants feel.Especially
down low in the revs.
Toshi did a remap on mine... good bloke, and knows the cars well.
spent nearly 6 hours doing the road tune to get it right...makes a noticable difference.
Best thing with toshi is that if your not happy he will keep going until you are and keeps the car at a safe tune..
If you want to know anything else let me know..
Scotty
YCOPY
Scotty
YCOPY
How was the fuel economy after the tune - better, worse or same?
fuel economy after the tune, it was close to the same..but the car has more power.
about 400-450kms (daily driving) per tank of v power (car was tuned on that) a little less on caltex 98 less power too.
Toshi said he could map for fuel economy or map for power...i went power..
Car is a 95 R33 GTST
mods...3inch exaust,pod filter,FMIC.
I increased the boost to from 7 to 10.
other than that the cars engine and turbo is stock.
no dyno yet, drifting i can feel there is a hugh improvment over STD i can hold a lot more speed sliding through corners, its kinda hard to explain but the power is there when i need it..you put your foot down and it goes..:D
There is more power all the way through the rev range and the car is very responsive, so daily driving is still fun too.
When i get there im going to speak to him in more detail.
I rather get the dyno tune done.
Testing on the road- well seems bit dangerous as theres too many factors involved.
I will find out on firday anyways.
Will post up the details then
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
