OK so a friend of mine looking to put his HQ on Nitrous. Track use only naturally
but having hassles finding some-one to refill bottles.
so looking for some-one who refill's on the spot (not swap overs as getting the tank airbrushed)
and the rough pricing for a 10Lb refill
any help would be appriciated
https://www.sau.com.au/forums/topic/210403-nos-query/
    • Close. Not quite. You’re on the right track. It’s a super obscure car that not many people in Australia own or would’ve even heard of. A hint: it was developed to dominate a gaijin racing championship.
    • Sorry for the confusion, I meant would there be heat buildup internally in the S3 that would be detrimental to the ecu situated under the seat but covered over as suggested
    • Navara? If it's a Bluebird, I might throw up in my mouth a little.
    • What heat build up are you asking about? Heat in the wiring providing the power to the Haltech, if remote mounted and power run via the fu(k-da-polees trick wire on the old ECU? Or heat from mounting an S3 inside an original case? I wouldn't run all the power for the Haltech through the trick wire. You just need the activation power. The main power would have to come from an appropriately fat feed. I wouldn't think you could fit the plastic body of a Haltech inside an original ECU case. They're pretty compact these days, but I don't think they're that compact.
    • Nope 😁 1999/2000 model
