Looking at doing the exhaust on my R32 GTR
Atm it has a stocko exhaust on it.
What im after is something free flowing, but quiet, i dont mind if its loud on full throttle etc, but just a bit quieter at idle etc
I previously had an xforce system and it was loud as all hell on my SR20 :P
Anyways
Im thinking of having a custom exhaust made up from an exhaust place in melb somewhere, maybe with a magnaflow rear muffler.
Or should i have a custom Dump/Front setup made, and purchase a jap brand cat back, i.e. HKS, kakimoto, fujitsubo etc.
Whats your opinion?
What exhausts do ppl have on their GTR's?
:D
https://www.sau.com.au/forums/topic/210752-exhaust-jap-or-custom/
custom = $$$ so i dont see the point honestly unless your going all out annd need something the jap brands dont offer off the shelf.
do what you gotta do with the dump/front pipes batmbl make some nice ones although im not sure if he does GTRs, but u should be able to find them anywhere. as for cats i would recommend catco, from personally exp they are top quality and picked mine up for about 400 from batmbl aswell. but make sure it is at least the same size as the dump/fronts to avaoid causing turbulence.
and if you want something quiet u cant go wrong with the Trust or HKS Silent Cat backs.
although its to quiet for my liking.
hit youtube and youll see wat i mean.
I think someone else made this point in another thread similar to this.
HKS and the other similar brands from Japan spend so much money It's not funny designing and testing these of parts. There is no way your local exhaust shop could match the R+D that would go into their exhaust. If you can, get the name brand stuff. You usually pay for quality.
i spose you gotta ask yourself, how much research and development goes into an exhaust
Went through this same dilemma.. Got quotes on some pretty big $ cat-backs.. (already have Garrett -5 turbos and Mines Dumps and Front pipes) Ended up buying a HKS Hi-Power Silent and its perfect for what I wanted. Bit of a lumpy burble idle, not too loud at half throttle so you can actually accelerate alongside a Honda Jazz in everyday traffic and don't sound like you're trying to race him.. (as if..)
Then when you get up it - makes a goooood note.. loud enough to be cool, but not "hey you, 3 streets over there - report me! I want you to!"
But as usual, as everyone here will say - what's perfect for me might be too quiet for you.. Bear in mind also, that if you have stock turbos, stock dumps and stock front pipes, that will probably also take some meat out of it... so it would be even quieter than what I have..
At your local exhaust shop probably none. At HKS however quite bit I would think.
These are the same parts they would have on their own HKS car, probably also the same parts on the cars they sponsor. When the main goal is to get exhaust out of the engine you don't want unnecessary bends, overly large bends or poor welds creating turbulence.
This is something I would think big performance part companies would be able to repeatedly test until satisfactory results are achieved and then have a computer recreate that perfectly every time after.
Then again I could be wrong and they could outsource them from China ;)
OH yeah, one more thing. The HKS exhaust was able to be fitted and hung in place in like 15 minutes.. And the welding and finish on it is really, really good.. just an extra bonus.. but it is definitely better made than 95% of the custom exhausts I have seen because most of it is done robitically I think.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
