CAN ANYONE TELL ME IF A 350Z A/T5 LSD WILL FIT A V35 C/P A/T5, AS ALL V35 C/P AUTOS ARE NOT FITTED WITH L.S.D. WHERE ALL 350Z 5A/T ARE. THEY BOTH RUN THE SAME RATIO, AND WHERE WOULD YOU LIKELY TO PICK ONE UP. ANY TECH HELP OR ADVICE WOULD HELP GREATLY.
https://www.sau.com.au/forums/topic/210951-l-s-d-for-v35-cp-5at/
good question, seems like a potential upgrade :cheers:
i'm keen on this answer too..
ps why are you yelling?
WHY, JUST ANNOYING I GUESS, IF ITS GOOD ENOUGH FOR THE 350Z WHY NOT V35 AUTOS, CANT UNDERSTAND WHY NISSAN JAPAN DIDNT INSTALL L.S.D.s IN THIS MODEL, MAYBE THEY THOUGHT THE V.D.C. WAS A CHEAPER WAY TO GO WHO KNOWS, ANYONE OUT THERE GOT SOME REASONS TO WHY THEY DIDNT FIT THEM, ITS GOT ME.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
