Hey!
I've been having this weird issue, thats on my nerves for quite some time.
When I coast on light throttle and suddenly apply more throttle. Like WOT, I get this clunk/kick in the drivetrain.
Or if I coast on light throttle and release the throttle pedal quickly. I also get this clunk/kick.
First I can feel it. Its like some kind of play. Probably the rear subframe/differential, cause I can sense it coming from there. Also the sound is from the rear.
If I raise the rear of the car. And try to move rear wheels by hand. I can feel there is small play until the diff(Nismo 1way) engages and spins another wheel.
Something like ~1cm play. I can rotate a wheel ~1cm forward and backward without engaging anything.
Anyone had similar problem ? What should I look for.
Sydneykid advised to look into final gear/pinion gear alignment.
Before I had a s14 3.7 final gear viscous lsd I didn't have this issue.
Car is A31.
Thanks in advance!
Yep sounds like play alright. Rear sub frame bushes rooted I guess. Drivers side front, check that bush. Big job, pain in the rear. Ive done two cars for other people, now my own has gone aswell. Oh well, the joys of owning cars
Also take a look at the centre bearing on the tailshaft, it can wear (moreso the actual rubber support that holds the bearing) & replicate the noise you're describing.
have you got excess backlash in the diff? Reach under and see if you can twist your tailshaft back and forth, there could be a big clearance between your crown and pinion wheel, which is giving you the noise on and off the throttle.
I have a similar problem on gear changes and the current suspect is the driveshaft appears to have some play in it, but I'm not quite sure yet...
Hey. It seems about right.
How do I fix it ?
  • 3 weeks later...
i got the same problem atm... im thinking of replacing all the driveshafts, thats the only thing i havent replaced. im taking my car into the shop tuesday so ill know for sure whats wrong.
I wasn't talking about cornering. I'm talking about straight line stuff.
2ways don't chutter on straight line.
Also. When in 4th/5th gear. If I start to play with the throttle. around 2/3k rpm. Like on/off operation. I can make my car to jerk so violently. Its crazy.
Need more input here, guys !
Thanks!
Interested in this, I get a jerking at really low speed if I try to slip the clutch.
I have the clunk on release/apply of throttle, and on every gear change, the diff has been rebuilt but that doesn't seem to be the issue.
I *think* we found a little slack in the driveshaft, although it still needs to be confirmed.
I have this exact same problem. I've apparently got a quarter of a turn in the driveshaft before the rest wakes up and turns with it :P Makes me jerk on gear changes and any momentum change, like I'm learning to drive manual. YUCK.
  • 3 weeks later...
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
