room will be the problem on that one. glovebox is VERY doable OR centre arm rest OR if you want to remake the rear seat centre section it would fit there. in dash - not easily.
as for quality same as the 8000.
  • Replies 44
garmin is RF based. no IR beam. the tv is IR. as for IR placement for the DVD unit - your call where it is placed. I have been putting them INSIDE the AC display to hide them - some are too big to do this though. any of the IPOD ones I do that is where they are. (oaksey if you are reading this that is where yours is.)
I see, I thought garmin was IR based too.
Is it possible to splice the TV's IR input wire so the same IR sensor would provide input for two devices? as long as the IR codes between the two device doesn't overlap each other...?
Alternatively, maybe you know of an in-car DVD player with an RF remote, that way it can be tucked away in the boot (something that takes like 6-10 dvds stacker), close the the pure tv's 2nd AV input.
nope separate sensors. I have a trick that I can use that WILL combine them but it involves another unit.
know of a 10 disc dvd unit but I'll have to see if it is still available.
Can you find out Chris, if the 10 stacker is a standalone (do not need a matching headunit) then I'd be interested. Is the remote RF? if so that will be a lot easier than trying to route another IR sensor to the front. pm me price to VIC delivered. I'll sort out installation here. cheers.
  • 4 weeks later...
Under the seat had the air-con vent thing, and it seems a little cramped under there. Was afraid it might get in the way if seat was moved back and forth. Plus people with dirty feet will kick it all the time.
I secured it with velco strips so I could move it anywhere if i don't like the position right now.
Forgot to thank you Chris for all the advice you've given me. You're a gem for V35 owners! :P
Ok guys one quick question regarding the head units being used.
In order to get the right input to the monitor (i.e. NTCS signal) are you using a US dvd player or some headunit that has NTSC out capability available here in Aus? Ive noticed a couple of said units available through Nesavision but they dont really do it for me and look a little boring. My thought was to look at getting hold of a headunit from the US and hooking that up. Would there be any problems with doing this?
From what i can see radio band frequencies are all similiar and the only difference would be the regionality of the DVD i guess?
unit needs to support local radio and local DVD regions. the USA versions do not. I get 2-3 questions a week on this and then 1-2 I should have listened replies.
dont really know what looks have to do with it. the unit is usually under a closed panel anyway.
Thanks for that, sorry to cover old ground but now i know for sure!
Cheers
I bought this unit from the US.
http://www.gooddeals18.com/c=T4pIjUKR7HKU5...oduct/PLD175TBT
-Bluetooth Handsfree
-DVD - I've only put in a burnt DVD so far and it works. Divx works too.
-MP3
-Radio - ALL aus channels
-USB + SD Card Slot
-NTSC TV Tuner - doesnt pick up Aussie channels
I'm one of the guys that gave chris one of the "should have listened replies" cos I complained to him that the TV Tuner didn't work. I really wanted the TV. Thinking about getting the Nesavision one just for that.. But I'll stick with this one for now. Only cost me $AUD 150 shipped.
  • 5 weeks later...
Hi guys,
I wanted to know where are the AV inputs in the car located, is there one on the back of the BOSE unit (i have the premium pack, no camera).
What i am going to do is just run the AV leads to my mobile phone so i can plug it into the system.
I have the Nokia N95 8gb, i think it a good solution for my self without any extra cost. So far I have 350 songs, FM Radio, some movies and GPS on the phone so it coveres what i need.
So where is the best location to connect the phone?
Thanks Chris,
The AV lead, can i purchase that in Sydney?, or is it something you have custom made yourself?, if so can you please PM a price including delivery to Sydney.
Im not sure what you mean when you say "rear deck - drv side"??
tv tuner location is what I meant- under rear parcel shelf drivers side. av lead is a special thing i import from overeseas. makes audio into these cars plug and play.
I found a 6 stacker quite a reasonable price: http://www.brashimports.com.au/DV680.htm
The install instruction is easy to follow so I wonder if I can tap to the existing DTV tuner power source as they'll be adjacent to each other in the boot?
but i'm not quite sure how to differentiate:
a) power ground
b) chassis ground
also what to do with the parking brake lead where can this connect to?
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
