If changing wheel studs on a vt commodore is anything similar to changing them on a r33, it's not all that difficult.
All you have to do would be, take off wheels, calipers, rotors and then you should be able to just 'knock' the studs out and replace with the new ones, reverse steps to get it back to normal. If the commodore and skyline are the same (for some reason I don't think they are) it should be a piece of cake.
yeah just as adam has said. and dont be scared to give the hammer a real good swing, just make sure you hit the stud, lol.
edit: it is also a really good idea to put a wheel nut back on the end of the thred befre hitting it with a hammer. it stops you from rounding the end of the stud over.
Edited by QWK32
thanks guys i was wondering cause they are longer wheel studs then the stock ones, i think the stock ones are around 45 mm the new ones i have are arond 75mm will they be hard to get them in the small gap at the back or is the gap at the back big.
cheers
Yeah, the 'gap' you're talking about could be a problem. When changing studs on the commodore, we had to turn the wheel to get the most space to 'knock' the studs in from behind. It could be more of a problem installing the longer studs though. Not sure what you could do apart from taking everything out. :thumbsup:
Hay guys,
i changed my wheel studs today.
i didnt realise that it would be so easy. i went to a few shops and they wanted about 60 dollars a stud to change over for me so basically i thought that was a jok so i will write step by step how to do it it took me about 20 mins each wheel to change them all up about a hour.
i also ran into a problem when changing them. i dropped my caliper which snapped a brake line. doh.
lucky for me the shops were close so could get another one made which was really good. that took about 2 hours in driving round but anyways.
Real easy to do.
step 1
Take the rim off
step 2
Undo the caliper. Two bolts at the back of it are all it takes to come off they are about a 17 mm i think.
step 3
There is a small part of steel which contects the brake line to the caliper. Thats what i broke and had to have changed. Remove it so you dont brake it. Its pritty easy to brake so be careful. Remove it it is a 10 mm screw on both ends of it. Brake fluid comes out but dont worry bout that not much comes out.
step 4
Take the caliper off the disc now. real easy it just slides off.
step 5
Get the disc off. that is also real easy. there are two holes on the disc that you can screw the appropiate bolt into keep going and it just falls off.
step 6
Now to the fun part with the disc off you can see the studs now i got new ones so i just smashed these original ones out. There is a place where you rotate them to hit out. Just hit the one that has the grove for it to come out.
step 7
Once they are all out. put the new ones in they will be lose dont worry bout that cause they pull themself into position when you tighten them.
step 8
Now put the disc over the studs that are lose and put the brake caliper back 0n and tighten everything up again. the studs will still be lose. now that everything is were it should be, put the new nuts you get with the studs on and start tightening them. when you tighten them they pull themselves into position and make there own groves in the hub. they really cut into it if you like. after they are tight take them off. you may need some one to stand on the brake while doing this so they dont move. by the way you might want to top up your brake fluid or bleed the brakes if you want to i did.cause of when you took the pipe off.
step 9
Now the studs are all tight put your wheel on, now what happens is you feel like you are stripping the bolt but your not. if you didnt get them tight enough they will still pull into position when puting the rims on so keep tighting them till they stop. thats it like i said it took 20 mins a side part from braking one of those lines i was talking bout real easy i saved a heap of cash dont be scared of doing it yourself.
:D Cheers guys i hope this can help others. later
Did you try to open up the brake lines to get the air in or was it by accident? There shouldn't be any need to take the calipers off the brake lines. Just un-hook it from the strut 'holder thing'.
Anyway, good write up. Maybe make a new thread in the tutorial/DIY section and copy, paste that post for others to see!
Cheers
Studs with wheel nuts together, where did you get yours, I got longer studs at like $6 each no nut.. ordered from repco, high tensile studs... I did need to cut them down a little though, but with wheel nut, what brand?
With wheel nuts, try to spend money on some quality ones. Those cheap ones from tempetyres, the tyre factory, etc, all break or round off after a few times after taking them off and putting them back on.
Go for Rays Engineering or Work nuts. A nice little way to spend $200. :laugh:
hay guys,
the wheel studs i have i got from auto one. they are high tensile steel really good quality they costed $13 a stud they came with nuts on them because they so long it was not a closed in nut which was really good. i got a total of 10 studs so i got them for 10 bucks each.
im not sure what brand they are.
hay dude i cant see why u would need to cut the stud mine were 75mm and fitted with ease. did u change the back ones.
i also took the brake caliper off so i wouldnt brake it you dont have to but i did cause it was a big hassel to get the hose i broke.
Edited by nm8u
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
