^^strange..
cos First defect 2 years ago was $98 at regency, second about 12 months ago was $140..
like everything.. the price goes up
Coming from a cop, and i know he wasnt talking shit..
Sorry, but I did only pay $54. Don't know where the $98 (or even $140) is coming from? :laugh:
You guys are getting ripped.
  • Replies 118
Then I'm obviously blessed to have paid $54. I'll keep it quiet now :D
$54 sounds like the price that Regency used to charge for a 2nd inspection prior to July 1st 2007.
If that was your 1st inspection then you they obviously wrote you up on the wrong register or tier group.....their bad, your luck.
Whiplash is clued up with this stuff, enlighten us with your knowledge & wisdom Nick.
4) no fancy supra's or stupid screamer pipes for those that have em.
lol sorry nathan but the 'fancy' supra has to be there. "stupid screamer pipes" LOOK WHOS TALKING! lol :D
I wander how many people are going to the cruise coz i have had a lot of people texting me saying they are going then i have people on the net saying they are going then i have people telling other friends to go lol.. well i think i know i have to print more then 20 sheets this time lol
Just checked my flight itinerary...arriving at 9.50pm... Damn.. :)
We'll still be out cruising no doubt.
Perhaps someone could swing past and save you a taxi fare? :rant:
I guess so. If thats not the normal write up, then I got lucky :rant:
Fri night cruise ;) ... i will be down there this fri night.. ;)
PM received mate. If Madaz can't pick you up about 10pm, I'm sure I might or someone else here. I need to check with the missus tonight, make sure there are no plans I forgot about. But other than that, I can collect you.
Are you stay at the Holiday Inn on Hindley St in the city? Can drop you off there too.
If I can't I'm sure someone else will be next in line ... right guys? :D
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
