i am a new skyline owner,i have a 1994 r33 gts-t with exhaust and air filter as only mods,i have filled my car up completely and have got 320kms and it says i still have 1/4 tank left.is there a fuel warning light on r33s just to let me know when im running low? my previous audi didnt have one and i ran out once:(
https://www.sau.com.au/forums/topic/212723-is-there-a-low-fuel-light-on-r33s/
Its a fairly faint brown light, hard to see in bright sunlight. Top Left of dash.
I didnt know i had one either, until one day i thought i was going run out of fuel, and then the fuel light came on for the first time - since then, ive worked out i have at least 30-40kms after the light comes on.
^^ Same here - one night i just kept driving around with the needle pointed on E (and the needle actually moves just under the E notch). I was pretty worried that i would run out sooner or later, and just as i rocked up to the traffic lights before the next servo i planned to stop at, the little orange icon lit up in the top left of the dash. I was cheering, I didnt think it had a fuel light at all.
Fuel light will come on when you're on E or just below. When it first comes on you still have a good 10L left (at-least), though you may find around corners your fuel fails to feed and you might chug a little! Haha.
But yeah, the fuel gauge is very lenient, it gives you heaps of warning. :D
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
