just dynoed my r32 gtst 5 speed and i was just wondering what power other ppl have and with what mods u have aswell...i drove my car onto the dyno did 3 runs and droive it off diddnt even check timing ... i just wanted to check air:fuel ratio for track day on sunday....
i have 243.6 hp at the wheels on 13 PSI
trust 3 inch cat back exhaust with totally std dump/front pipe and cat
hybrid 600x300x76mm cooler
mines ecu
gtr fuel pump
std turbo
hks power flo filter
thats all that i know of/can remember at the moment....
:P
https://www.sau.com.au/forums/topic/21294-r32-rb20det-5-speed-rwhp-outputs/
Generally the Standard Turbo's won't make any more than 160-170rwkw no matter what other mods you do.
This is 214rwhp-228rwhp.
UNLESS you have a nice little RB25DET turbo hanging off the side then that power is around the mark.
Different dyno's also vary. I've had my car on 2 different dyno's both were Dynamic Dyno's. It made within 5rwkw of each other.
But they were both using the same software version etc.
One was used for dyno tuning almost 100% V8's the other was 100% turbo's etc.
You are making around 181rwkw.
I made 164rwkw on 15psi or 220rwhp.
Its basically the limit of the turbo's as they arn't able to flow much more air to make more power. You can up the boost a little more I guess but then the ceramic exhaust will will probably disagree. :P
Loading her up on the dyno it made full boost (15psi) by around 2500rpm. Or on the street 15psi is 3400rpm in third gear.
the air/fuel was a little rich up top but thats all good...... time for more boost :)....
as far as i know i do still have std turbo but i was told through another person that it had a rb25 turbo installed at one time but i diddnt think it did... maybe i was wrong..... i have dyno sheet that says 243 rwhp so im happy eitherway lol......
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
