Hey guys, looking for some R34 Nismo Skirts like picture below. Genuine is best but non genuine i will consider. If already painted factory silver then that would be a bonus.
like these pictured below (same colour too :D)
PM or hit me up in here
https://www.sau.com.au/forums/topic/213074-wtb-r34-nismo-side-skirts/
Hey, they are not Nismo side skirts, they are Nissan dealer option ones. How do I know? That's my car and I got the front bar and skirts from a guy in Sydney who was fitting a kit.
Yeh... I know they are meant to be called the Nissan Alita (from memory) skirts, but generally they are dubbed the nismo skirts so to maximise the hits for the thread I just kept it at that :P
Altia make the rear wing, Aero is the official name of the skirt.
Doesn't matter anyway.. everyone knows the skirts you're talking of :thumbsup:
Lol ok then well I couldnt see how someone could make such a good front bar and skirts but muck up a Rear wing so much!
Glad to know that terrible spoiler is made independent of the rest of the kit
So yeh, aero skirts anyone?
we have access to these skirts and we can make a mould and put them in production for you
your looking at $220 a set plus shipping australia wide:
Sydney: $30
Melbourne: $40
Brisbane: $45
Adelaide: $49
Perth: $ 89
Hobart: $69
Darwin $89
like these pictured below (same colour too :thumbsup:)
Good to see you're getting a kit on, any luck finding the rear bar mate?
I hate the 'aero/altia' rear bar, too boxy and that part with the skyline writing sticks out like dogs b@lls.
P.S I stumbled across here coz I was trawling the wtb to see if anyone wants some perfect working oem gt-t coilpacks for cheap, know anyone?
Edited by Yo-Yo
Im the same, i really dont like the rear bar!
yeh planning on slowly getting there. if finding these skirts is this hard for a reasonable price, i cant imagine what finding a genuine type s rear bar like yours will be like!
Well ill keep that in mind about the coil packs, because i have developed a misfire. Im thinking ill check the plugs first, but they will be my next line of fire :thumbsup:
price?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
