Item: JayCar Independant Electronic Boost controller
Age: New
Condition: Wonderful - put together, but never used.
Price: $50 (kit price is $80 when buying from Jaycar)
To Fit: Any car (works with Stock R33 boost solenoid)
Contact: through this thread or PM
Comments: you can find all the details about this controller from Jaycar ( LINK )
And you can read the review that our own Sydneykid gives it Here
Pic here
Will post anywhere at your expense.
Willing to swap for Stock R33 Air box and snorkel
What this like compared to a apexi hks unit??
How much are the hand controllers??
It works differently to the other Boost controllers.
as Gary puts it...
http://www.skylinesaustralia.com/forums/in...t&p=1159436
Hand controllers??
http://jaycar.com.au/productResults.asp?FORM=KEYWORD
Edited by GTST
as Gary puts it...
Hand controllers??
Hey have you had it working in your car??
