Hi guys....
Im thinking of buying this car from QLD.. and i live in melbourne. is there a special way to register that car in victoria?? whats blue slip?... and is there a way of getting the car here without driving..(like ship )... any rough idea how much that will cost?...
If anyone knows anything abt this... please reply for this topic....
thank you very much in advance..
https://www.sau.com.au/forums/topic/213358-how-to-buy-a-car-from-out-of-state/
hey dude, i just bought my r34 gtr from sydney a week ago and its pretty easy to get everything done.
basically i would get an inspection done unless you are gonna go down and inspect it yourself, a professional inspection cost about 300bux from companies like VIP automotive whom can also arrange transport.
shipping from syney to melbourne usinf CEVA logistics (formally TNT) cost about 500bux for an open truck but generally will incur some stone damage on the way so make sure you get the insurance with it as my car got its winshield and front bar damaged which im getting fixed soon.
otherwise pay the extra for a closed truck container which is made for luxury and race cars but is more pricey.
fill out a transfer of ownership form and get the seller to do the same and go to vicroads here (you will require a RWC) pay the stamp duty and other fees and your done!!
-Johnny
-Johnny
Thankx johnny.... its very help fulll..... and the rwc... is it has to be a qld one. or victoria one. or doesnt matter.... do you know that?....
must be a victorian one!!!
but its handy to get one from the sellers state to so at least you know there shouldnt b a problem getting one here.
i wish you all the best of luck if you end up getting an out of state car and if u need any more information please dont hesitate to ask!
-Johnny
-Johnny
Thankx mate.....
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
