i had that same problem with my RB25DET mate.....my problem was that my Harmonic key was rooted....it was advancing and retarding timming as i was driving it.....and my revs were doing that as well....it would jump up and down rapidly on idle......so might be worth checking that....i had to replace my motor...goodluck
My R33 was sluggish and i had the cam angle sensor turned left (counter-clockwise) and it increased response and power (10rwkw extra). Did it on a dyno- best way because you can measure the changes to the power curve. Turning yours right might've made it worse.
It's something else you've missed i reckon. A smic swap (i've done the R34 one too) shouldn't do anything other than allow more charge to flow through the intake.
Edited by R338OY
yeah i had the r34 cooler in... then i swapped back to the stock smic cuz this stupid problem.. which i cant figure out what to do...
when i turned the cam angle sensor as far clock-wise as possible it made more power and even more drive ability but its still nothing like it used to...
engine has around 90,xxx kays on it..
only has a pod and turbo to tip zorst..
changed plugs for brand newies around 1000 kays ago..
do oil and iflter every 4000 kays,,
suck a f**king annoyhing thing..
i dont understand whats the go with this ecu diagnostic shit..
their is a tiny red and green led light on the actuall ecu.. they flash and shit when i turn that small screw all the way clock wise o the ecu..
the cat temp sensor light in the dash flashes on and off..
i dont know how to decifer them fault codes and that... what to count and all that :S
im shit i know
haha
cheeeeers
search the forum for ECU+CODES
there was a thread with what each light flash meant.
also, I'm thinking that if all this started with the SMIC install, are you absolutely certain the the 2 rubber joiners for the cooler are not cracked.
have you removed both off the car, cleaned them and thoroughly inspected them?
remember that those rubber joiners have probably not been touched for about 15 years and perhaps as you removed the stock cooler (the pipe has a lip on it) it may have cracked the rubber a little or enough to cause a leak.
it's free so might be worth checking.
i just wrote don how many times them leds flashed and that
i got
2 slow flashes
3 fast flashes
4 fast flashes
5 fast flashes
1 slow flash
2 fast flashes
?? dont know what the shit that means
and also while im waiting for a reply for the ecu codes i checked all cooler piping.. even on the throttle body.. both for the cooler every connector i could see.. their all clearlly old. but no cracks inside or out....
mate seriously.
search.
I just typed in ECU+CODES just like I told you to do...
and look what happens..
http://www.skylinesaustralia.com/forums/se...2BR32+ECU+CODES
Now look at the 6th thread down.
Now look at the 3rd post.
surely you could have done this yourself.
Edited by GTST
haha yeah rb20 slug.
took it to a local work shop but they could not find a thing wrong with it... no ecu fault codes showed up...
well when i was playing with it in my driveway it turned out to be the plug for my cam angle sensor was rooted and my timing belt was possibly put back on wrong as if i tried to back the timing off anywhere away from as far advanced as it would go the car would start doing the eratic idle....
i have just brought brand new gates racing timing belt and have rb25 turbo and greddy front mount to go on soonish along with a speedlab ecu remap..
cheeers for all your help guys :)
yeow
yes.. its a fair clean ceffy.. i wouldnt mind eventusally dropping in a rb25... but its a matter of cash like everything else. haha
make the rb20 boogy a bit first.. have fun with it will i got it
cheers guys
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
