Nissan Skyline r33 1996
Approx 85xxx kms
Manual
Sonic silver
Located in sydney
This car has been well looked after and is in prestige condition - mainly a weekend car . no scratches on this car nor any panel damage . never been in an accident . basically i am selling this because i need a cheaper car for the time being . i am willing to trade with other CARS only , maybe cheaper value of coarse . if you have any interests in a trade = do run it by me .
the car comes with a list of extras such as :
18 ' mono block rims - lenso
trust pod filter with custom enclosure
full alarm system and imobiliser
after market gear knob
pod pillar with boost and air/fuel gauge
sony head deck and kenwood speakers
sub and amplifier
silvia badge
turbo back exhaust
hi flow cat
jap type cannon
twin split dump pipe
side skirts and rear pods
6000k philips headlights
front mount intercooler
hks turbo timer
gfb bleed valve
tinted windows all round 15%
lowered on king springs
the car also has had a recent service so its running tip top . i am asking 16500k . can be negotiable depending on circumstances. im in no rush to sell - if i dont get the money i want i wont sell.. car has rego till november . pm me for info or give me a call if your interested in a direct sale . cheaper for cash . 0434465302
Edited by sky-017
if anybody is interested in a cash sale , please give me a call , and i will make a negotiation on the price . car is going on carsales this week . need to have it sold soon as i am looking at purchasing a new car this week,
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
